JY
I am a rather new owner of a Cat 30. Not too much experience in sail design. Any opinions would be gratefully acknowledged. I am having a new mainsail made by a local sailmaker. The boat is a 1977 Catalina 30 tall rig. The new sail has battens on the 1st and second position from the top along with a mid sail full batten and a fourth partial batten toward the foot. All looks standard. The upper area of the sail with the two top battens brushes across the backstay by a few inches in that area due to a larger than original roach. The batten pockets are reinforced and covered with a clear plastic cover. So, when the sail tacks from port to starboard and back again, the top two battens can slide over the backstay in that area. The sailmaker states that this design gives added drive for the main and has used this design for several years with no problems or complaints of rubbing on the backstay. He said he stands behind te design and any future wear if present would be taken care of by him. I am an occasional sailor on Lake Erie in 5 to 20 knt wind.What is your opinion. Have you seen this design before. It reminds me o the shape of a sail on a catamaren design. I hope the description is adequate for you "old hands" to envision. Thank you/
