Further Info.
Dale, you don't mention if you have the original traveller car still attached to the track? If you do then its a simple fiddle block sheet system replacememt. If you don't, you need to measure the width of the track to match the replacement car. You can upgrade at this point to a bearing type car, but there pricey. If you want to just replace the original, which just slid across on its own surface, and had 2 screw-pin stops, determine make, and width. I'm not sure if it's Schaefer or Kenyon, as O'Day used both of these manufacturers.For a better look at what you need, go to rigrite (link below) and nose around there online catalogue. You can give them a call, as they know the O'Day line of boats intimately. And there is always Rudy at D and R marine fame. His # is listed many times in many former posts.Don
