Main sheet on MH 37?
richk
Jan 24, 2007
495
Marlow-Hunter 37 Deep Creek off the Magothy River off ChesBay
I need to replace the mainsheet on my Marlow Hunter 37. Any suggestions on diameter and type of line?
Rich in Annapolis
BobH57
Oct 23, 2019
91
Hunter 410 Solomons, MD
Rich,
There should be a spec page in your owner's manual with line types and sizes. I just ordered a new mainsheet for my H410 from SBO, and it's 1/2" Sampson XLS 80' length (I actually upped it to 85').
Johnb
Hunter 37-cutter Richmond CA
My HC 37 has 5/8 line for the main sheet. I suspect that was chosen more for being easy on the hands than for strength. I was given a self tailing winch which works, but not really well, with the line and for that reason I am going to renew with 1/2 line which will fit much better. I think I will imitate BobH57 for type and size.
richk
Jan 24, 2007
495
BobH57 and Johnb
Thanks for your responses. Gonna check it out. Current main sheet needs replacement.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
I could not find a Hunter 37 manual with a list of lines. My recommendation is to attach a tag line and remove it and replace with same length assuming you are happy with that length. That way you can ensure you do not buy extra unuseable length. That is what I do when replacing my mainsheet. Hunter specifies 11 mm (7/16 inch) diameter Samson XLS (or equivalent) for the mainsheet for your boat size.
