Main sheet configuration 331
E
edsouthall
Does anyone have any experience of altering the mainsheet on a 331? I find the standard system stiff and difficult and not easy to sail close to the wind because of the lack of a track.
E
Ed
No traveller
Do you have a traveller then as the layout on mine has no means of moving the mainsheet to windwardand no way of getting the pull on the base of the boom upwind of the midline Ed
Liam
Apr 5, 2005
241
Beneteau 331 Santa Cruz
No traveler??
I did not know that this boat was built without a mainsheet traveler. My mistake. I have a 2003 model and it has a traveler. Sorry for bad previous advice.
E
Ed
traveler
Many thanks Was it fitted by Beneteau or added later? don't suppose you have a photo you could send me? my email ed@southall.name best wishes
Liam
Apr 5, 2005
241
No Photo
Hi Ed, No I do not have a photo. I can tell you however that the coach top was designed for the traveler and has a moulded in mounting surface. The traveler is only about 48" wide but does the trick. Harken and Schaefer make a Bridge Traveler system that should work nicely. Good luck, Liam
