I used some plastic board I had sitting around, some longer screws and a Harken Cam-Cleat to add this. In light air the cam cleat takes the load and in heavier air the jam cleat does. Works great. Ray
My original idea was that I wanted to just raise the cam cleat hoping the more extreme angle would give more bite, but that didn't work. So I cut a new piece that was longer and added the cam cleat behind the jam cleat. The cam cleat I am using now (not the one in the picture is a [FONT="]Harken Carbo-Cam Model 365). As it is carbon fiber, it is very smooth to operate and does not chew up the rope. I have attached a drawing of the dimensions. Note the 1/4" cutout on the one side as it butts up against other installed clutches. Plastic board is what I have always called poly-teak and it is the marine board that west marine sells - I used 3/8" thick stuff. It is a little pricey, but I had some sitting around (actually it was in the trash) that was just enough. [/FONT][FONT="]There is also a 2nd smaller piece you need to cut for the cam cleat to sit on so it is raised up enough from the output of the jam cleat. [/FONT][FONT="]The cam cleat end does hang over so that the ends of the screws can fit - they also do not penetrate the hull or gel coat. I don't recall their length, but they are just long enough to go though the cleat and the two piece of board.So you raised the original Jam cleat as well.
Did you do this because the aluminum backing plate did not extend far enough aft to provide proper anchor for the cam cleat? Thus the screws that mount the cam cleat have nuts inset on the underside of the plastic board and don't penetrate the deck at all. Only the original bolts that mount the jam cleat hold the entire assembly to the deck. Nice design. What is "plastic board"?
Tom
There is no problem. The jam cleat lines up the line for the cam cleat and I screwing the jam cleat down into the original factory holes.for your detailed response!!
I may have a piece of white Corian that should work.
How does the horizonal offset to the winch affect the feed over the inside cam under load?
I will let you know how it turns out.
Tom
