Here's a pic of my 1984 Hunter 31. This isn't specific to the boat though. It's a pretty standard setup and most likely stock. I want to run the main sheet to the rear of the cabin roof. The easiest option is to use the winch and brake, but I really don't want to do that. I like being able to hold the sheet and control it if I so desire. I'd like to use a swivel cleat, but can't find one that would work. I only want one sheet run to the rear so it has to be useable from the opposite side of the cockpit. A standard swivel cleat with an eye doesn't seem to be a good option for controlling it at close to 90 degrees. I'd like something like the Ronstan RF70, but I can only find those in tiny sizes. I also want it to uncleat when pulled down. Any ideas?
Also with this setup, I always see the sheet routed like so:
front block > boom base > mast base > organizer > cabin
It seems that the boom base block is not needed and could rout directly from the front block to the mast base. That makes the system a little simpler and still keeps the load axial to the boom.
