Sail Shape
Mast bend helps you control the amount of power you'll get out of the main. Since there is no running backstay (nor is there a Cunningham) on the 240, I don't think you have as much flexibility for depowering by flattening the main as you would on a boat that has those features. If the vang and outhaul on a 240 are already maxed (assuming the main was hauled all the way up - look for the black masking tape near the top of the mast) there is nothing else that I am aware of (short of easing out the main and/or reefing) that you can do with the rigging while underway to depower. In a boat with a running backstay, putting bend in the mast by tightening the back stay will flatten the sail and depower it.I guess the point of all this is that when you are tuning the rigging, you might want to think about the prevailing conditions you are sailing under and put in the amount of prebend for those conditions, i.e., if you constantly sail in heavy wind, then you might want to put more prebend in the mast. Although it will slow you down in lighter air, it will give you more control in heavier air and, in my view, allow you to hold off on reefing just a bit longer.At any rate, this is how I've approached the matter for the last two years - If anyone thinks this is off the mark, please let me know. I love getting advice from this forum.Good luck with the 240!
