DIY
Hello Scott: As a confirmed DIYr, I always do all my own sail repair. If I understand your's, it's at luff end of batten, easy fix. Remove sail,batten and all hardware near tear. Use 5oz cloth for repair. Cut 1'' wider (top to bottom) than tear, and 1' longer (to wrap around sail) Wrap repair cloth around luff, use basting tape to hold in place. Use home sewing machine (mine's kenmore) with #18 needle, and G69 dacron thread. In a pinch you can use fishing rod repair thread. Now sew straight stitch tightly against luff rope, then zigzag stitch around patch and across tear. Two rows are better than one. BTW I just finished modifyingStock main on my h27 to full batten. Cut 18" off foot, and gave it a nice rounded leach, used 6 battens. Made a huge difference in weather helm, and sail is much easier to control with no noticeable loss in power. Good luck red
