blowing in the wind
It's very exciting to sail the boat in 25 knot winds, but not much fun for the non-sailing crew. The reef that comes with these boats is actually what would be considered a second reef point in larger vessels. As mentioned the boat is somewhat unbalanced with only one sail up, but not too difficult to control. You will find that sailing close to the wind becomes very slow and painfull when the sail area is greatly reduced because of higher winds. This is in part due to the high freeboard which competes with the reduced sail area for moving the boat. The ballast is neccesarily higher in the hull and therefore the righting moment is less so the sail area must be reduced further than deep keeled boats when close to the wind in a breeze (tender,that is it heels more).I have used either reefed main or head sail alone when reaching in a blow and am not sure which is better. The head sail with roller furler can be greatly reduced in area, furled quickly if needed, and you won't notice if it jybes. However, it will give you lee helm (spin you like a top when control is lost), can jam, and will not go to wind if furled more than 30% or so. The main when reefed will go to wind (slowly), gives weather helm (anoying but safer than lee helm), and looks nicer. If you jybe the main in a blow you can damage the boat and demast. You could also kill someone with the mainsheet or boom. In 20 knot winds with no experienced crew or when children are aboard you are probably best off droping sail and motoring. Don't forget sails will not last as long when subjected to higher winds. Then again this is a sailboat. alan
