Joel
Have now had a few chances to actually sail my 1987 H23. I'm still amazed at how nice it sails. I do have one question for those with this style of H23.The other day when out in the ocean, the wind was coming across the stern at about a relative bearing of between 135-165 degrees. To actually catch the wind, I had to let the main out quite a bit but noticed that in order to get it where I really wanted it, you could saythe imprint of the spreaders in the main. If the wind was coming anymore from the stern, I would have never been able to getthe main out far enough. On other boats I have sailed, I've always been told to keep the sail oof the spreaders.Is this just "normal" for the wing keel H23s? Are the side stays perhaps not adjusted correctly causing the spreaders to sweep aft more than is correct? Everything on the boat is still "standard" equipment.
