Has anyone done any work on the Titan model 60 coupler? the shock absorber inside the unit is causing a bump when pulling the trailer. Any sources for parts?
purchased from Champion (link provided by Rick W.) I changed over the drum brakes to disk brakes on all 4 wheels which required a new coupler. The Tie Down gear is high quality.Fair winds and roads,Tom
are out of adjustment, the clunking is the master moving throught its full range of movement, about 1-2 inches. All that could be needed is that the star wheel adjuster inside the drums needs to be turned a bit to push the shoes more towards the drums.
