magic tilt trailer
BART
Has anyone done any work on the Titan model 60 coupler? the shock absorber inside the unit is causing a bump when pulling the trailer. Any sources for parts?
May 27, 2004
225
- - Boston
Replaced it with Tie Down Eng unit...
purchased from Champion (link provided by Rick W.) I changed over the drum brakes to disk brakes on all 4 wheels which required a new coupler. The Tie Down gear is high quality. Fair winds and roads, Tom
Mike
It could mean that the rear brakes......
are out of adjustment, the clunking is the master moving throught its full range of movement, about 1-2 inches. All that could be needed is that the star wheel adjuster inside the drums needs to be turned a bit to push the shoes more towards the drums.
