macgregor 26s ballast
hedgy
Oct 5, 2019
7
macgregor 26s Umitalla
good morning, i just purchased 1993 Macgregor 26s, wondering as far as water ballast, its trailered waiting to get in water but i went and tried to check seals for balast, filling from top and lower seal leaked majorly. is this right or is seal bad, and where can i get new seals. checked all over internet
Are you talking about the ballast tank seal under the boat? If so, then you definitely need to fix the seal. Otherwise on a long reach, you will loose your ballast. I don't know what the valve looks like on a Mac but I made mine for my H26. I made a "damn" around the valve cover and filled it in with goop and let it dry.
Here is a post from a few years ago
I have also heard of people taking an old mouse pad and cutting it into the right shape and using that for a gasket.
Aug 26, 2019
45
Hunter 260 Eau Claire
Look up Blue Water Yachts in Seattle. They should have them.
Jun 1, 2015
217
Macgregor 26d Trailer Estates, Fl
They have them and are inexpensive enough that it’s not worth making your own. On this page you can find both the complete assembly and just the gasket: Hull Hardware Check the description to be sure they match your boat.
My only beef with BWY is the shipping will likely be equal to the cost of the gasket. I try to group items I buy from there for that reason.
I don’t think SBO (the gracious sponsors of this forum) have them as I couldn’t find them with a quick search.
Tedd
Jul 25, 2013
750
TES 246 Versus near Vancouver, BC
I agree with williamtl, shipping is the only down side to BWY. But if you spend a little time on their site you're bound to find many other thing to piggyback on the order! I keep a "wish list" going there and then if I need something in a hurry I pile on items from my wish list.
Addendum: I recently took a little extra time to fill the ballast an inch or so above what I used to do and I was impressed at how big an improvement it was. Now I fill that sucker right up every time.
CaptVR
Nov 17, 2018
21
Macgregor 26X St.Petersburg, Fl.
I have a Mac 26X, same thing, center hull fill pad rubber hard and leaking. Bolt heads wear corroded enough that major time pulling it apart for new rubber pad seal wouid be needed.. I cleaned the old pad good, dryed with a hair dryer. and made a nice 1/4" O ring around the periphery and a couple cross pad on back side of the bolts. Let it cure for two days and reinstalled. Worked perfect, still working a couple years. Worked like a large O ring glued to the pad. I used Dow 795 silicone, had it left from window replacements. Capt Vince Rakstis, Ret.
Likes: hedgy
Jul 7, 2004
8,402
Hunter 30T Cheney, KS
You just have to wait long enough for the tank to equalize with the outside water level. The manual says you should be able to touch the water thru the air hole when it is full.
Feb 1, 2011
10
Catalina Macgregor Hunter 14.2, 26CB , 33 Cherubini Stuart
On our Mac 26 we use a little petroleum jelly as a seal dressing for the lower seal and upper hardware. I would pull the assembly and check it over for porosity corrosion (esp. at the weld joint) and if the seal seems good (not stiff and cracking) I'd try to lube it before buying a new one.
We replaced the whole assembly through BWY and when I tested it on the trailer it leaked before using a seal dressing.
On the upper hardware the petro jell keeps the hardware from binding and giving a false sense of tightness.
Aug 1, 2011
3,972
Being a rubber gasket, it will degrade over time. A 1993 gasket doesn’t owe you anything :)
