I bough my first boat (a 1997 Macgregor 26X) last summer, and I started by checking and setting the shroud tension to what I found to be "recommended specs". However, I could not bring the tension on the upper shrouds to 300# because when I adjusted the tension plates to this level, I was not able to pin the forestay. So, I ended up lowering the tension to an acceptable level but I want to set them correctly this spring, and I guess there should be a way of increasing the tension on the shrouds after the forestay is in place.
What I did when I set the tension was to lower the mast, adjust the chain plates and raise the mast again (several times) until I reached the correct tension using a loos gage. However, there must be a way of adjusting the tension after the mast is raised.
I know this is an old topic and I have reviewed many posts in several forums but I would appreciate if somebody can tell me what I should do to adjust the shroud tension after the mast is raised and the forestay's pin has been put in place.
