Macerator Pump simply installed
Jan 18, 2014
238
Hunter 260 Palm Coast, FL
Doug, I would recommend just have another good look through the wood board covered openings of the aft berth floor. I did not have conduits either (maybe the boat dealership installed the marine head on my boat). I routed through the floor without any problems a pipe for my cockpit shower and several conduits for all kinds of cable like solar power or a second battery. You can see the battery cable in the first and second picture in my previous post. You should have any no trouble going going from the bathroom all the way into the area behind the vertical aft berth wall.
Hart
Doug J
May 2, 2005
1,192
Hunter 26 Oceanside, CA
That's encouraging Hart! I will remove the aft berth wall to really see what I have.
Jan 18, 2014
238
Doug, I meant also to look under the aft berth floor. You can reach easily to route through to the area behind the wall.
-na -NA Anywhere USA
The basic 260 and 26 are the same. Changes were in the cockpit and forward on the 260 as much of the interior remained the same. On the 26, one would need to remove the rear berth wall and install a platform on the 26 suggesting a 20 gallon holding tank and pretty much go with the design of the head on the 260. The run of the discharge line should be short as possible and do not forget to install a vent.
