This may be interesting for some of you. I have an 13 Gallon holding tank on my H260 and it doesn't really take long on a several days trip of two to fill it up especially by generously flushing.
Since located on the Intracoastal in Florida I have to get out on the ocean to sail and reach easily beyond the two miles.
I was tired of finding pump-out places and thought of a macerator pump but did not want to go through the hassle of a inboard solution with installing switch, cutting pipes, through hull, etc.
Interesting is that the 1-1/2" thread of the macerator pump, I used the Jabsco 18590-series, fits exactly into the thread of the outside tank flange and seals on its own. I used screwed the pump in, used a short hose into the water and a flexible cable, when needed, to connect a moment it to a 12V outlet in the salon.
It works very well and I can now after pump-out rinse the holding tank bei filling up with some water via the marine toilet, sailing for a while to have the tank plenty shaked and pump it out again. For this was never a chance at a pump station.
The pump is a multi fit; thread followed by a 1" long hose barb. I cut the hose barb off, it was too long for the tank flange also removed the mounting piece from the pump with the four rubber screw holes since not used. That was all to do.
