This may be TMI , and I apologize for leading you astray on the bolt location we both learned something new . As your hole is below waterline and into the ballast tank something like the repair in this video would be better than putty imho.
Number one, don't worry about repairs, until you see where the water is coming from. You will have to lift the boat off the trailer some to remove the centerboard. This might be a good idea just for checking the CB penent. After removing the CB, start filling the BT with a garden hose while looking up into the CB trunk to see exactly where the water is coming from. Now, you can determine a plan of action... Capt.Vince Rakstis, Ret.Thank you for this advice. I have a1999 Mac26x. Definately a leak in the centerboard trunk. No leaks show on any visible part of the hull. But water pours out when I pull the boat out of the water with the gate valve closed. I do not have a threaded valve. Just the gate valve on the transom and a vent hole forward under the V-birth. How would I access the centerboard trunk to check and repair. Once I drop the centerboard, will I have enough room to reach up into the trunk to effect a repair of the fiberglass?
CaptVR Thank you for the advise! I have fixed the problem for now. The centerboard pivot pin had punched a hole in the ceterboard trunk opening the ballast tank to the open water. I plugged the hole with a fiberglass and epoxy patch. It is working well for now. I do appreciate the insight!Number one, don't worry about repairs, until you see where the water is coming from. You will have to lift the boat off the trailer some to remove the centerboard. This might be a good idea just for checking the CB penent. After removing the CB, start filling the BT with a garden hose while looking up into the CB trunk to see exactly where the water is coming from. Now, you can determine a plan of action... Capt.Vince Rakstis, Ret.
I was a marine surveyor for 30 years, built six boats.
PS:
Hi, Vince here, I took a close look at mine, with the way it is put in there, I do not think it lends a great deal of structural strength. Taking out the front section by the door and the lower inboard sections are very thin frp layup, does not look or feel very structural, and looks as though it would come out relatively easily. But the back section and wash bowl area would be very difficult to get out, and the raw inner hull would be exposed. With the floor liner still in place with the ballast tank well still in place, I don't think you are going to gain what you think you are, especially for the work involved. I've looked this over myself, and elected to leave it as is. I have been pondering cutting down the ballast tank tower and glassing it all in, like the later model 26x's and moving the vent / fill forward to the v-berth as on the later model 26x's. Then putting a folding up SS steps so you have a wide open lower entry across the whole front. I was planning on a battery bank for solar on the outboard starboard side of the aft birth. Also putting a hanging locker on that side, and making that aft bunk narrower to maybe a twin size berth. If you would like to chat, my phone is 727-515-5021, e-mail me your number so I can expect it. I get 5-10 spams a day, so I vary rarely answer long distance numbers unless I know the number. Have a great day, CaptVR "Vince" My regular e-mail CaptVRakstis@yahoo.comCaptVR Thank you for the advise! I have fixed the problem for now. The centerboard pivot pin had punched a hole in the ceterboard trunk opening the ballast tank to the open water. I plugged the hole with a fiberglass and epoxy patch. It is working well for now. I do appreciate the insight!
I have another modification issue that you might be able to give some info on with your years of experience. I find the Mac26x head compartment to be too confining and blocks access to the under cockpit "pizza oven" double berth on the starboard side.
I want to remove the head door, cut out the top half of the head walls, and sinks and replace with a curtain situation. My question is "Is that molded head compartment inner lining structural? Would I weaken the integrety of the hull or deck by removing 3/4 of it?" If not, I think this would open the boat up alot, give more room to use the head, and give decent access to the double berth under the cockpit.
Eager to hear you thoughts.
