I am a new owner of a 1976 Mac Venture 25 and a novice in this size sailboat. I am in the process of rebuilding this project and have some questions about the rudder-tiller and was wondering if anyone can help with information about this subject. I am also a new member on this forum.
The rudder-tiller looks like it is either teak or mahogony. The rudder (segment that sticks in the water is all sanded down, and it has age-drying cracks) and I was thinking about fixing this portion. What would be the best way to rebuild this segment. The cracks could be filled with a marine epoxy or wood filler, then what would the next steps be? Finish the wood with marine varnish, then put fiberglass matting over, then fiberglass resin, then antifouling paint?
The next item is the wood portion of the rudder system that goes veritcal connecting the lower rudder to the tiller. That section is junk and I need to replace it. I do not know if this is teak or mahogony. Is there a good place to buy this wood. The size piece need is about 38" long x 11" wide x 1-1/4" thick. I thought of contacting a local cabinet shop to find the wood.
The tiller segment just needs sanding and refinishing. Does anyone know of a good marine product that is best suited for the finish on teak or mahogony?
Next question: The entire rudder system was taken apart. I also am looking for a diagram or drawings to be able to put the rudder system back together including the rigging of it. In addition, is there a diagram or any drawings available out there to be able to get the dimensions of the vertical wood rudder piece to make a new one as mine is damaged. I know this is alot of information needed and if anyone could help, suggest or point me in the right direction I would really appreciate it. Again, I am a novice at this so I could really use advice on this. Thank you. David
