Mac 25 Rudder question
Nov 5, 2014
31
MacGregor 25 St Marks FL
Hi, I just bought a 1985 Macgregor 25 which needs a bit of work before I get her into the water. I am also very new to sailing so have lots to learn. I am having trouble figuring out how the kick up rudder is supposed to be rigged. At present it is fixed with two bolts, but I know that it should swing up for shallow water/ launching / trailering etc. There is one block attached down near the waterline on the starboard side of the rudder that I believe is used to pull the rudder down into position. I believe that ideally it would stay in place, but if it should strike something it would swing up. I expect shock cord plays a role somehow. Does anyone have a diagram, or photos of how the rudder rigging is supposed to work? The following photo shows what I have. I would sure appreciate any help anyone could provide. I have been able to find answers to a lot of other issues online, but not having any luck on this particular question.
3,983
somethings wrong there.... it looks like a fixed rudder, not a swing up...
a kick up rudder has a 3/4" pivot bolt near the top of the rudder thru the rudder post at the bottom.
your rudder doesnt even look like it would hang down in the water far enough to properly control the boat under sail....
it should hang at least 3ft below the boat....
post a few more photos from different angles, and a close up of the rudder post where the rudder attaches.... it would help
Feb 20, 2011
8,062
Here's what your kick-up rudder configuration should look like.
The rudder hold-down on mine is routed to a self-releasing cleat, just in case. ;)
8,062
You're quite welcome. Looks like you've got it figured out.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
Looks like you have it. The hole below the pivot point is for a plastic bolt. Plastic so it breaks when you hit something with the rudder.
The releasing cleat is a great alternative and easier to use.
(My Siren has a bungee cord that supposedly keeps the rudder in place. It doesn't work all that well. I have resorted to just tightnening the rudder so it will swing when I hit something but is so tight the water motion won't move it.)
Mar 20, 2012
3,983
the object on the tiller (handle) is a "tiller tamer", its a good little item if you dont have a tiller pilot, but not related to the swinging up of the rudder... search tiller tamer and you will find out how it works.
Kestle
Jun 12, 2011
702
MacGregor 25 San Pedro
I have one and they work great, if there is no play/movement at the pin/rudder stock intersection.
If there is play, go to McMaster Carr and get a sheave, drill out for it, and have it welded in place on the stock. Also, add some anti-corrsion goo to where they meet, as plain aluminum and stainless will corrode the hole bigger. Some use a plastic insert instead of a sheave.
Jeff
Nov 5, 2014
31
Thank you. So much to figure out.:)
