Mike Elmore
I just bought Windward Hull last year. It's my first boat. I've been learning things as I go. The manual I have has incorrect directions for draining the fresh water coolant. Engine maintenance is one of the things I have (up until now) left to the yard and it runs fine.Now that I've had the problem with the cracked water lift chimney, I had to get the coolant out of the exaust manifold so I could unbolt the header pipe to get the pipe/hose off the water lift. I'm embarassed to say I had to syphon it out the coolant fill cap.The manual says that there is a drain petcock for the coolant on the block below the alternator. There's surely nothing there. The diagram (and motor) has a drain plug on the starboard side of the motor close to the oil dipstick. Is this the freshwater coolant drain?On refilling, just refil until it's full up to the cap and then check for air pockets? Also...I have a coolant resovour in the port lazarette. It has a hose attached to the bottom of it that runs to just under the coolant cap so it can drain into the exaust manifold as needed I assume. There is a clear 1/4" hose attached to the top that just runs down into the engine box and attaches to nothing. Is this clear hose a breather hose so the plastic resovour doesn't collapse? ...or should it be attached to something to make it a closed system?Any help is appreciated. I've got a handle on enough things that it's time to not have to pay anyone for engine maintenance anymore.Mike ElmoreWindward HullC28 - Hull #7
