M25XPB Oil Dip Stick
DaveJ
Apr 2, 2013
526
When checking the oil level on this engine, should you insert the dipstick all the way into the hole, pull it out and look at the level, or insert only until the rubber seal on the dipstick touches the block? The manual doesn't specify....
Cheers
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
All the way down. That's standard on all dipsticks except some that screw in, where the manual usually specifies.
MitchM
Jan 20, 2005
1,031
on yan mars you must NOT screw the dipstick in as it will give a false reading. on something this important, get some advice on your particular engine from a manufacturer's rep --not the internet.
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
On Universal engines the dipstick goes all the way in.
May 20, 2016
3,015
Agreed all the way in for the engine. But unscrewed for the Hurth transmission
What Les stated on Perkins engines.
