John
My C30 has a m25XP and I want to no what speed I should be runing at.I no i should run at about 2/3 full power but Im not sure what that is I have a three blade prop . And at 2000RPM im runing about 4.5 kts but at 2500 I run at 5.25kts There are alot of people that go alot faster? I never run more then 2300 .The reason im wondering about this now is that im haveing a starting problem . My moter allways starts on the second try it seens not to matter if i use the glow plug or not I have some fuel seeping from the starbord side of the moter around the fuel filter?Its not enough to make a drip but it is wet.It could be oil but i dont think so.Could i be sucking some air and need more cranks to presher up to start? how about this. Could i be runing to slow and fouling my injectors? I ran about 1/2 hr at 2500 and the next day it started up on the first try on the first crank maybe the prop is no good some one painted it with a copper anti foul and it is pitted up a bit . I use a fule additive for smoke and bugs and stuff.when sailing i reach about 4.5 to5 kts with new sails150% head sail and FB main I have a tall rig my bottom needs to be striped and re done what do you guys think.
