Unlike a Yanmar, for example, the Universal bleeds the system mechanically. You open up the bleed screws (one at a time in the proper order) and then turn the engine over. There is no kingston pump to manipulate. Most likely you have introduced air into the system and there are usually three things that keep a diesel from running or running properly: air, water or contamination.
