I have a 2004 O'Day 34 with an M25. Last time out at higher RPMs, there was a whining followed by a loss in power. I took her out of gear, lowered the RPMs and reengaged. It happened one more time then ran fine at lower RPMs to get back to the slip.
I went to check the transmission fluid and the dipstick is not on the bolt where it should be. Could the issue I experienced be the missing dipstick or something else?
Any thoughts would be appreciated. Thank you.
