Merry Christmas to all of you.
I have an on going problem with the engine in my 1980 Catalina 30 that drives me to distraction. I love the boat and I know the boat. The only disappointment is the engine - an M18 Universal. I have been on this forum many times trying to figure out if it is running right or just down right undersized. The consensus is that it is just too small for the size boat.
I am still, however, trying to boost the power a bit because I feel that there is some mechanical problem that is making this small engine smaller.
I have rebuilt the injector pump (blowing smoke and that did the trick). I put in a new fuel pump, changed filters, cleaned out the tank and speak to it gently every time it starts but I find that the maximum RPM that I get under load is 2,300.
When the boat was pulled, I took off the two blade prop and found that it was a 12 incher. I do not know what the pitch is but I will be bringing it to a shop for measurement in January. The specs call for a 13x10 for maximum performance.
The question is: Is this undersized prop a potential cause of the low RPM? I would hate to invest in buying a 13x10 for no reason.
