Larry, I think I may have sent you links to our C34 tech wiki before, but if not, go look here, scroll down to M25XPB Kubota material.Would like to cross reference the Kobota part number
Correct - especially if.connected to big lug and not the little push connection on the starter solenoid.Yes but as I interpret the schematic it also is wired to the starter.I guess you are saying it is getting current from the starter not send current to the starter?
I don't think it was the factory, Les, those solenoids came with the newer bigger engines, IIRC. I might be wrong...since my engine is almost as old as Les'!!!I’m not sure when the factory started installing relays for the GP, but it’s a common mod, and lots of people use ford starter relays (overkill IMHO)
You're very welcome, glad to be able to help.What I couldn't find was a reference to Kubota D10005 having a lift pump or glow plug solenoid.
