Scott
Help..!!!I had a problem today with my 1988 Catalina 27 with a Universal M-18.I was running the motor at about 2900 RPM when it started to make a "loose change" ratteling sound. It appeared to be coming from the belt driven Fresh Water Pump on the motor. Not the raw water pump. I quickly reduced the RMP within seconds which in turn stalled the motor. I tried cranking the motor to start it, once stalled, but it would not turn over. The resistance against the fresh water pump was to great. The crank shaft and the alt. appears to turn ok but the fresh water pump does not. I believe I have a bad "seized" Fresh Water Pump ???? Any advise on this matter before I buy a new one and replace it?????Thank You....
