Hello all. new to the forum. I have done a search and guess I am the only one with this problem.
I have a C27, 1984 with a Universal M-18 engine. I have a exhaust leak somewhere on the engine as I can see a very slight haze of "smoke" with the engine compartment light off while using a flashlight.
Soapy water all over the engine and exhaust has yielded nothing, the water box is good and all connections to it are solid.
What I have found is a rather large amount of "air" coming out of the valve cover "breather outlet", the right elbow connector that is immediately forward to the oil cap on the top of the engine. If I place my finger over it to "plug" it, when I remove my finger it sounds like a air compressor releasing it's last 10 psi. Why would this breather vent have so much air or maybe its exhaust coming out?
The engine seems to run just fine without any issues. Cranks on the first 1 - 1 1.5 rotation no abnormalities at all. I was thinking, could the decompression lever not be fully releasing or could this be pressure coming from the crank below the pistons and I am having blowpass from weak rings and the crank case is somehow venting through this top "vent" as there does not seem to be any other vents on the engine.
Thanks a million and so glad I have joined this forum, as a first time sailboat owner in summer of 2019.
