Ok Guys I know that someone out there has an answer to this question.I have a new sail on order with slugs on the luff, I leave my main flaked on the boom with a cover when the boat is on the moorings.Question - Do any of you know of a product that you insert into the luff grove feeder slot once the sail is on the mast (closes the feeder slot back to the same size as the luff grove) so that when you drop the sail the lugs dont fall out? I know that some of you have talked about slug stops that you can place in the groove but these keep the sail 12 inches off the boom which means I will need a new boom cover as well.I have seen such an item (plastic insert) on the web but can't remember which site, any help would be appreciated.ThanksMike
