After six years and one month, it seems that my house bank, consisting of TWO Duracell Group size 31 Model # 31DCX (mfg 6/20), has finally bit the dust. Their periodic consumption of distilled water has gone up significantly, and the other day in a critical situation, they failed to start. Yesterday, I added a total of about half a GALLON of distilled water to top off all three batteries, when I usually use less than 500 ml during a season.
The situation was after spending a night at anchor in the Kickamuit River, I was trying to exit the Kickamuit under sail. While I was approaching R N "6", with the current against me, the wind died, or I was in the lee of the houses on the west bank, and the boat speed dropped to 0.4kt against a 0.5kt current.
I was fortunate to have bank 2 fully charged, so I quickly dove below deck, flipped the switch to bank 2, and got back to the helm. I started the engine, and got back on course without running aground.
Anyway, I will be looking for new Flooded Lead Acid batteries for my vessel. I'll replace the start battery while I am there, because I would like to keep them all about the same age. Right now, I am looking at 2 EverStart Group 29 Deep Cycle batteries, because I can't find Group 31 Batteries anywhere in southeastern Mass or RI.
During the season, I keep the batteries charged by a 100 Watt Solar Panel, which is then connected to a Victron Energy MPPT Controller, which is set up for Flooded Lead Acid Batteries.
If it helps, here is a schematic of the charging setup of my primary electrical system;
TLDR; I am looking for battery recommendations. I am currently planning on 2 EverStart Maxx Group 29DC batteries from Wally-world for ~$260.
Change my mind!
Change my mind!
