lube for Hood Roller Furler
64
Catalina 30 Ruskin/Tampa Bay
Suggestions on what lube to use and where to apply the lube on a Hood Roller Furler. Just spalshed from the winter and the furler is very hard to furl??
Ron
Chels-A-Bella
C-30 3532
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
If you have the owners manual for the unit there should be annual maintenance instructions on where to lube your Hood unit.
We have a relatively new Furlex unit that came with a tube of 'special' grease for lubing the fittings and the manual tells you which parts need it. That said, I would think that something like this would do the job a little better then Vaseline: http://www.defender.com/product.jsp?path=-1|311|296536|314204&id=851293
If you can't find the manual for your Hood RF unit like I did online for our Selden Furlex system then just lube the obvious moving parts and bearings. It is likely that the instructions for lubing a Hood furler are similar to Harken and other brands if you can find their owners manuals and can't find anything on Hood.
Also, make sure you used the right halyard to raise the jib and check for halyard wrap around the top of the furler as this condition is not good. Break out your binoculars and check the top of the mast carefully.
Good luck.
Feb 10, 2007
213
Hunter Legend 40.5 Coconut Grove, FL
Fresh water flush, a lot of water so the salts, grim and dirt leaves the bearings. No lubricant required.
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Hood says at the end of the season, remove the head and soak in soapy fresh water....thats all that is needed. I also thoroughly rinse the head unit each time when I get back from sailing as the salt build-up can be hell on the unit
Good Luck!
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Read my manuals maintenance instructions this past weekend. Rinse with fresh water every few weeks. It is supposed to be permanently lubed, but if it is tight they said to spray the bearings with WD-40.
