We are currently restoring a new to us 1984 Beneteau First 38. It has a mid-1980’s vintage propane (LPG) 2 burner stove with oven manufactured by ELECTROLUX. It is stainless steel, gimbaled and still in “like new” condition. Apparently not used much. It is currently set up with propane as fuel with propane locker in the port lazarette. The storage locker has the required gas “drain” to allow heavy propane gas to escape from the locker.
We are considering changing over from propane (LPG) to CNG. Has anyone done this?
Since the LHV (Low Heating Value) of LPG and CNG are different, I would expect that it might be necessary to change the jets on the burners where the fuel and air are mixed. When you change over a cooking stove or gas furnace in your home (from LPG to natural gas or reverse) you need to change the jets. I would expect the same when changing from CNG to LPG or the reverse for a marine stove.
Why CNG? Here in Chicago many of the taxis use CNG for fuel so refilling tanks will not be a problem. With the abundance of natural gas here in the USA, I expect both LNG & CNG to become popular fuels for buses, taxis, 18 wheelers, etc. CNG filling stations will become more common.
CNG, which is mostly methane (CH4) and LPG, which is mostly propane (C3H8) & butane (C4H10) have drastically different vapor densities. CNG, lighter than air, will rise and dissipate if there is a leak while LPG, heavier than air, will descend to low points, accumulate, & concentrate to the point where the mixture can become explosive if there is an ignition source.
Also, CNG, which is mainly derived from natural gas, will probably continue to be rather inexpensive here in the USA while LPG which is mainly propane and butane will be more expensive since it is a feedstock that can be processed/upgraded to more valuable products.
