New Hunter 36 has small lpg compartment only holds the 4.25lb/1gal cylinder by Worthington. Boat less than 6weeks old and LPG cylinder rusting away. Does anyone know who makes aluminum sized tank? Has this issued been discussed? I believe that either make the compartment bigger to accomodate a larger aluminum tank or Hunter should get a supplier that can manufacture these small tanks out of aluminum. Steel and salt water do not mix very well. I hope I am not over reacting, but after spending $ on a new boat... well you get the point. Then again, if this is all I can come up with to complain, I should be thankful.Any comments appreciated.Abeand yes I searched the archives, and internet.
