Lpg Control
13
Hunter 49 Now in Antigua
I have a problem with the cooking gas switch in the galley labelled LPG CONTROL. Can anyone confirm the rider from left to right for the cables. I have three two single cables one orange with red stripe one orange with green stripe and a pair of yellow cables into a single point. I can email a photo of it it that helps.
I appreciate your feedback. Local EXPERT wants $100 call out fee plus $100 for first hour or part thereof.
Cheers
AB
Jun 15, 2012
719
BAVARIA C57 Greenport, NY
The orange/red is LPG power to switch
The orange/grn is LPG solenoid from switch
The 16 gauge yellow is the indicator light ground
The 14 gauge yellow is the LPG solenoid ground
When you turn on switch, does indicator light glow? If it does, problem is in wiring to solenoid or solenoid is kaput.
Aug 27, 2012
13
The indicator has never worked but the switch was working. Now we have no light and no gas.
Can you confirm if the order you describe is the correct order of the cables as described from left to right (when looking from above with the switch facing out) ?
Thanks again.
