Lowering the Mast with a Tabernacle Mast Step
Apr 2, 2013
283
Hi ric,
Order me one as well.
Larry
Sent from Mail for Windows 10
Sent: Monday, February 29, 2016 4:35 PM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Lowering the Mast with a Tabernacle Mast Step
Steve,
I don't know yet. I haven't ordered one because I'm not ready to do the mast and rigging yet. Although I'm getting close. I came across this site several years ago from someone else that had it on their Vega. The hinged base will definitely make raising and lowering the mast a much easier process. I'll be ordering one within the next 30 days or so. When I get it, I can take lots of pictures of it for you.
Ric
s/v Blue Max
#2692
www.ric-maxfield.net
Oct 15, 2015
206
Am I reading this correctly? Are we talking about a tabernacle or a hinged base plate for the mast? I like the idea of a tabernacle more than hinged base plate due to strength, stress considerations. The video of lealea that Chuck showed in my thought was a hinged mast base plate. Anybody have pics of a proper type tabernacle? Thanks for your patience...Cheers
Dec 14, 2013
50
Albin Marin Vega 27 Venice
Dear Alaskayfish,I just posted some photos of my Vega (Spray, hull 3339) with the tabernacle system.I purchased her in Holland where this system is used a lot because of the canals and bridges.Arend Schram is an expert of this system.Contrary to the system showed in the Video from Chuck, this system requires an arch which acts as a lever. It also requires that the upper shrouds are hinged at the same level as the stainless steel step hinge. It raises and lowers the mast backwards, so no need to have somebody on the pontoon in front of the boat to help. I have been raising and lowering the mast several times with the help of my Brother and I am happy with it. As you can see, I have been motoring through the Dutch canals with the mast hinged and lowered. If necessary, it is possible to lower the mast just 30-40° to pass under a bridge and then raise it back.This system is slightly different from the "Sprague" PDF mast raising and lowering one (available in the files session). In my Vega the mast is stepped on the stainless steel hinged base. When raising and lowering my mast, I do not attach the forestay to the arch bar (as in the Sprague drawing). This because I have a roller furling system. I attach the genoa halyard. An assistant has to accompany the furling forestay system.Hope this helps,marcoAlbin Vega 3339 Spray From: "alaskaflyfish@... [AlbinVega]" <AlbinVega@yahoogroups.com> To: AlbinVega@yahoogroups.com Sent: Sunday, 6 March 2016, 20:38 Subject: RE: [AlbinVega] Lowering the Mast with a Tabernacle Mast Step
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987 --
#ygrps-yiv-1407678387yiv3426963987ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp #ygrps-yiv-1407678387yiv3426963987hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp #ygrps-yiv-1407678387yiv3426963987ads {
margin-bottom:10px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp .ygrps-yiv-1407678387yiv3426963987ad {
padding:0 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp .ygrps-yiv-1407678387yiv3426963987ad p {
margin:0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp .ygrps-yiv-1407678387yiv3426963987ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ygrp-lc #ygrps-yiv-1407678387yiv3426963987hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ygrp-lc .ygrps-yiv-1407678387yiv3426963987ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span {
font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span span {
color:#ff7900;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span .ygrps-yiv-1407678387yiv3426963987underline {
text-decoration:underline;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach div a {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach label a {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987bold a {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 dd.ygrps-yiv-1407678387yiv3426963987last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 dd.ygrps-yiv-1407678387yiv3426963987last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 dd.ygrps-yiv-1407678387yiv3426963987last p span.ygrps-yiv-1407678387yiv3426963987yshortcuts {
margin-right:0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987attach-table div div a {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987attach-table {
width:400px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987file-title a, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987file-title a:active, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987file-title a:hover, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987file-title a:visited {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987photo-title a, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987photo-title a:active, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987photo-title a:hover, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987photo-title a:visited {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div#ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg #ygrps-yiv-1407678387yiv3426963987ygrp-msg p a span.ygrps-yiv-1407678387yiv3426963987yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987green {
color:#628c2a;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 o {
font-size:0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987photos div {
float:left;width:72px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987reco-category {
font-size:77%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987reco-desc {
font-size:77%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987replbq {
margin:4px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg select, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 input, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg pre, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 code {
font:115% monospace;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg #ygrps-yiv-1407678387yiv3426963987logo {
padding-bottom:10px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-msg p#ygrps-yiv-1407678387yiv3426963987attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-reco #ygrps-yiv-1407678387yiv3426963987reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-vital ul li:last-child {
border-right:none !important;}
Oct 15, 2015
206
Marco, Thanks for the pictures of the tabernacle. Your example is exactly what I was considering when referring to a tabernacle. I like your system very much and will use your pictures as a guide to fabricating one of my own. Any other information on this modification that you think is apropos please let me know... Best regards.....Tim Malone
Mar 11, 2013
17
I have a tabernacle on my Cotillon (AV3364) , she was most of her life in
Holland, where tabernacle is very commune.
the picture is the same as mine work fine never had any problems
KR
stephan*Stephan Zarzecki*2016-03-06 19:38 GMT+01:00 alaskaflyfish@... [AlbinVega]
AlbinVega@yahoogroups.com:
Nov 8, 2001
1,818
I have drawings of the Dutch style tabernacle if
you email me at steve@...
Steve B
[AlbinVega]
Sent: Monday, March 07, 2016 6:54 AM
Step
Malone
This email has been checked for viruses by Avast antivirus software.
www.avast.com
Apr 2, 2013
283
Steve, could you send me a detail of this as well?
LarrySent from Mail for Windows 10From: 'steve@...' steve@... [AlbinVega]
Sent: Monday, March 7, 2016 1:58 AM
I have drawings of the Dutch style tabernacle if you email me at steve@...
Steve BFrom: alaskaflyfish@... [AlbinVega]
Marco,
www.avast.com
Apr 2, 2013
283
Marco,
Could you send a picture to me as well?
LarrySent from Mail for Windows 10From: alaskaflyfish@... [AlbinVega]
Sent: Sunday, March 6, 2016 10:54 PM
Marco,
Nov 8, 2001
1,818
Hi All
I will sort photos and drawings if
needed
Steve Birch
[AlbinVega]
Sent: Tuesday, March 08, 2016 4:51 AM
Step
Steve, could you send me a detail of this as well?LarrySent from
Mail for Windows 10From: 'steve@...' steve@... [AlbinVega]Sent:
Monday, March 7, 2016 1:58 AMTo: AlbinVega@yahoogroups.comSubject:
I have drawings of the Dutch style tabernacle if you email me at steve@... Steve
BFrom: alaskaflyfish@... [AlbinVega] Sent: Monday, March 07,
2016 6:54 AMTo: AlbinVega@yahoogroups.com Subject: Re: [AlbinVega]
MaloneThis email has been checked for viruses by Avast antivirus
software. www.avast.com [Non-text portions of this message have been
removed]
www.avast.com
Apr 12, 2016
102
If I'm not too late to the party, I'd be VERY GRATEFUL for pics/drawings
as well!! We just purchased Vega #3360 (if I'm reading the hull number
correctly) and in the near future it will be an absolute requirement
that we can raise and lower the mast ourselves. THANK YOU! - Gene Neill
Oct 15, 2015
206
After much searching, I found that Ballenger Spar had the best quality mast hinge. I just installed it tonight and it looks good. It is a little more expensive than the others available but it is worth it.
Apr 28, 2000
691
There are articles on the mast step and the procedure on the American
Vega Assn. web site as well as a couple of videos on YouTube of it
being done. It has been discussed quite a lot here in the group as
well so you could search the archives to review the discussion. I
will see if I can find some good photos of the step on Lealea, but I
think I published some in the newsletter years ago.
"Fair winds"
Chuck Rose
SV Lealea, V1860
