Dear Alaskayfish,I just posted some photos of my Vega (Spray, hull 3339) with the tabernacle system.I purchased her in Holland where this system is used a lot because of the canals and bridges.Arend Schram is an expert of this system.Contrary to the system showed in the Video from Chuck, this system requires an arch which acts as a lever. It also requires that the upper shrouds are hinged at the same level as the stainless steel step hinge. It raises and lowers the mast backwards, so no need to have somebody on the pontoon in front of the boat to help. I have been raising and lowering the mast several times with the help of my Brother and I am happy with it. As you can see, I have been motoring through the Dutch canals with the mast hinged and lowered. If necessary, it is possible to lower the mast just 30-40° to pass under a bridge and then raise it back.This system is slightly different from the "Sprague" PDF mast raising and lowering one (available in the files session). In my Vega the mast is stepped on the stainless steel hinged base. When raising and lowering my mast, I do not attach the forestay to the arch bar (as in the Sprague drawing). This because I have a roller furling system. I attach the genoa halyard. An assistant has to accompany the furling forestay system.Hope this helps,marcoAlbin Vega 3339 Spray From: "alaskaflyfish@... [AlbinVega]" <
AlbinVega@yahoogroups.com> To:
AlbinVega@yahoogroups.com Sent: Sunday, 6 March 2016, 20:38 Subject: RE: [AlbinVega] Lowering the Mast with a Tabernacle Mast Step
Am I reading this correctly? Are we talking about a tabernacle or a hinged base plate for the mast? I like the idea of a tabernacle more than hinged base plate due to strength, stress considerations. The video of lealea that Chuck showed in my thought was a hinged mast base plate. Anybody have pics of a proper type tabernacle? Thanks for your patience...Cheers
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987 --
#ygrps-yiv-1407678387yiv3426963987ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp #ygrps-yiv-1407678387yiv3426963987hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp #ygrps-yiv-1407678387yiv3426963987ads {
margin-bottom:10px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp .ygrps-yiv-1407678387yiv3426963987ad {
padding:0 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp .ygrps-yiv-1407678387yiv3426963987ad p {
margin:0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mkp .ygrps-yiv-1407678387yiv3426963987ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ygrp-lc #ygrps-yiv-1407678387yiv3426963987hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ygrp-lc .ygrps-yiv-1407678387yiv3426963987ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span {
font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span span {
color:#ff7900;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987activity span .ygrps-yiv-1407678387yiv3426963987underline {
text-decoration:underline;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach div a {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987attach label a {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987bold a {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 dd.ygrps-yiv-1407678387yiv3426963987last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 dd.ygrps-yiv-1407678387yiv3426963987last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 dd.ygrps-yiv-1407678387yiv3426963987last p span.ygrps-yiv-1407678387yiv3426963987yshortcuts {
margin-right:0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987attach-table div div a {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987attach-table {
width:400px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987file-title a, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987file-title a:active, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987file-title a:hover, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987file-title a:visited {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987photo-title a, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987photo-title a:active, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987photo-title a:hover, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div.ygrps-yiv-1407678387yiv3426963987photo-title a:visited {
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 div#ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg #ygrps-yiv-1407678387yiv3426963987ygrp-msg p a span.ygrps-yiv-1407678387yiv3426963987yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987green {
color:#628c2a;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 o {
font-size:0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987photos div {
float:left;width:72px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987reco-category {
font-size:77%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987reco-desc {
font-size:77%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 .ygrps-yiv-1407678387yiv3426963987replbq {
margin:4px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg select, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 input, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg pre, #ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 code {
font:115% monospace;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-mlmsg #ygrps-yiv-1407678387yiv3426963987logo {
padding-bottom:10px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-msg p#ygrps-yiv-1407678387yiv3426963987attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-reco #ygrps-yiv-1407678387yiv3426963987reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-sponsor #ygrps-yiv-1407678387yiv3426963987ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1407678387 #ygrps-yiv-1407678387yiv3426963987 #ygrps-yiv-1407678387yiv3426963987ygrp-vital ul li:last-child {
border-right:none !important;}
