Need some more help. The photo shows a slot in the mast just below the spreader that anchors the top end of the lower shroud. It's about 3/4" long and 3/8" wide. There used to be a plastic spacer or insert that surrounded the edge of the slot, but it split and fell out. The end of the stay still fits OK, but it has a tendancy to slip out until the mast gets part way up. What is the item called, and does anyone know where I might be able to order one? I haven't had any luck searching for it. Thanks.
Jon
Jon
