Over the last 2 months I've been noticing my solar has been having trouble getting my two group 27 batteries wired in parallel (but with a switch to isolate them) back to float stage, and they have not been maintaining a charge quite as well. I assumed it was simply because I added the Auto Pilot this year and I've been using it quite a bit, and I've just been running the batteries down lower than I have in the past, resulting in longer recharge times.
After my trip to Block Island over Labor Day with all the motoring we did that shouldn't have been an issue but we still ran the batteries down a bit. I hooked the batteries up to a autozone car battery charger (I don't have a regular shore power charger) and let that sit overnight at the 2amp setting. It still never came up to what I feel was a proper 100% charge, so I knew that there had to be something more going on. After disconnecting the charger last night I checked the water levels and found that Batt 1 was topped off, but Batt 2 was down roughly 2oz of water per cell, although none of the plates were exposed, I'm sure they were when heeled over, especially since I have not rotated my battery boxes yet per your recommendations on orientation.
I added a total of about 14 oz of water to the battery (6 cells, just over 2oz each). I last checked the battery levels this spring, and they were full then.
Should I be concerned that one battery boiled off that much water while the other didn't, and should I be concerned that the water level got that low, even though the plates would have only been exposed at heel, never at rest?
Aside from keeping a closer eye on the water levels of the batteries, is there anything else I should do?
