I am helping a friend with a Yanmar 3gmd raw water cooled engine. I stated that he would have to get a dock hose to get the raw water to come out the exhaust then it would be fine. Kind of like an air lock. Then the last time that did not help and the engine over heated.
I know enough to help a bit. The first thing I did was pull the raw water pump and check the impeller. It looked fine but went ahead and replaced it. Put it back on still no water. I chased water through the system and got blocked at the exhaust elbow. Replaced that and thought would be home free....No. Now that the raw water pump could push water the seal was leaking badly. So I got a new seal and after a lot of headache replaced the seal.
Still no raw water. At first there was a bit and I could definitely hear it gurgling in the hose but no significant discharge. I thought it might still be air locked and used dock hose to no avail. Took the discharge side hose off the pump while running and no water. The strainer is relatively high mounted so I took it loose and dropped it to the water line. No. I have sucked water through every hose and no blockage that I can find.
The only thing I can think of is for what ever reason the raw water pump is not pumping. But that is hard to believe or the exhaust box is completely stopped up.
Any thoughts on this? I am banging my head now! I was originally going to replace the raw water pump but it is not the $125 variety like mine it is the $435.
Thanks!
Thanks!
