My Yanmar 3GMF (1983 Hunter 34) does not run above 2500-2600 RPM"s in neutral or in gear. The manual calls for 3600 wide open. It has run at the same RPM's since I got the boat three years ago. I have changed the fuel filter and have removed the entire mixing elbow to clean but stil the same RPM's. A couple of questions:1) Is there any special way to clean the elbow? I don't know how "clean" the passages need to be. Upon initial inspection it doesn't appear to be blocked but there is alot of carbon in there on the walls.2) If it's not the mixing elbow what do I look to next?I have very little smoke at the exhaust. Sometimes when I start the engine after a long layoff it will smoke a little (blueish). The only other time it smokes is when I'm docking in my slip and I need to give it lots of power quickly to maneuver.Thanks for any advice.Joe Mullee
