Hi - How much RPM should I expect getting under full throttle underway (i.e. in gear) on an O'Day 26 with Yanmar 1GM inboard Diesel engine?
While in gear, the maximum RPM we see under full throttle is 2600 rpm. Without load (i.e. without gear) we see a little above 3500 rpm. Clean hull and prop. The 2600 maximum under load seem rather low?
Thanks!
Thanks!
