I have an O'Day 272LE with the Westerbeke 10 Two diesel inboard engine. When I turn on the ignition key the low oil pressure and high water temperature alarm activates as it should. Once I start the engine and the oil and water temperature gauges come up to normal operating specs, the alarm continues. I have replaced the alarm and the same thing still happens. I traced the two wires back to the engine which connect to the wiring harness located next to the pre-heat solenoid.
Anyone have experienced this and have some answers?
