I am looking for your experience and ideas.
I have a 21 hp Westerbeke 3 cyl diesel (1983), freshwater cooling. Within the past few months, I have replaced the mixing elbow (6 months) and the impeller (3 months). I have low flow of cooling water coming out and as the engine warms up, I get steam. On the last trip out i had to dial back the speed as the engine temp was rising a little.
I pulled the end caps off of the heat exchanger to see if there was stuff plugging the flow. There is some scale on the tubules as can be seen in the attached photos. The other side of the heat exchanger looks about the same. I wonder if there is more scale in the middle. There were two bits of pencil zinc in one end and I pulled those out. That didn't help.
I find that when I first start the engine, I get ok flow (but only just ok). As the engine warms up and when I crank up the rpms, the flow seems to be less. When the engine is hot, even when I dial back the RPM, the flow doesn't seem to come back.
I am wondering if any of you have some ideas or experience with similar sort of problem. Should I try a phosphoric acid flush of the heat exchanger?
