C
carisea
I performed maintenace on my jabsco electric toilet. replaced impellor,removed salt and gunk from impellor and now I have lost prime from the thru-hull. I have tried backflushing from the toilet intake hose up and over the siphon break and water seems to flow out of the boat. I then close the thru hull valve and immediately slam the hose onto the pump intake port and clamp in place. then I open thru hull and hit electric switch. pump runs but no water is coming into bowl. I do not want to do this for too long or I will burn up new impellor. I even found the solenoid that supposedly closes when switch is pushed and plugged the end of the siphon hose to make sure are was not getting in system and I can still not get water to show in the bowl. Since this is the method I used on the first toilet and got a good prime I am at a loss to figure out what else to try HELLLLP!!!!
