A week ago my Catalina 30 Universal diesel overheated. Since I didn't have any history of when the thermostat was last changed I decided to change it. After changing the thermostat and bleeding the system it tested OK at the dock. Taking the boat out and running the engine for about a total of 40 minutes it appeared that I solved the problem. When I was going to use the boat a few days later I checked the coolant level and it was low. I had to add about 3/4 of a gallon to bring the level back up. It appears that I am losing coolant when running under load. There is no coolant in the bilge. No signs of leaks I think it must be mixing with the raw water and going out the exhaust. What steps should I take in tracking down this problem? Past history of the cooling system is in 2004 the water pump, circulator pump, all hoses and hot water heater was replaced, also the heat exchanger was upgraded to 3"
Any help will be appreciated.
