Here's the situation on my 4JH2E in my Hunter 40.5:
Last season:
Further reading in ssca and in a sister forum ( and many others) led me to realize that:
Thanks!
/ed
Last season:
- Broke V belt, twice, overheated, but turned off immediately after alarm sounded.
- Fixed pulley alignment issue.
- Finished season without issue, including some long full day motoring.
- On launching, all looked good until about an hour later while picking up the mooring. Overheat alarm.
- Freshwater coolant is losing about 1 quart every 15 minutes and after about 45 minutes it overheats.
- Put a loopback on the hotwater heater to isolate the engine. It still leaks.
- Pressure test (in isolated mode) shows that it is losing pressure. Can hear air/water flow in exhaust.
- I can see the fresh water level decrease after filling.
- I left the 'Peace sign gasket" ( O ring with a chord) off because I did not remove one. While this probably affects performance, it appear to only isolate the input from the output.
- There are periodic surges of pressure in the fresh water tank. ( "Scuba Like" per forum)
- Upon starting the engine after the pressure test, it was difficult to turn over.
- Exhaust had a bit of white/grey smoke, but not obviously water vapor.
- Does the presence of surges in the fresh water tank indicate a head crack or head gasket leak? (if not, what is it from ?)
- There is a reference to an issue with the mixing elbow. I can't see how this can be related. Am I missing something?
- Is my conclusion regarding the 'Peace sign gasket' well founded?
Thanks!
/ed
