I'm puzzled by your suggestion, R.W.,
unless you don't have internal halyards, topping lifts, etc. If you foam a section of the mast, how can you lead lines or messengers through the mast in the event you break a line or want to add a new one?I had an internal slap problem some years ago. Decided to run new and improved coax cable for the VHF radio and as I fed the new cable into the mast, I tied wire ties around it every 24" or-. They press up against the inside of the mast. No noise, no problem. I remove all the lines from the mast every season and leave messengers, take them home, throw them into a bag, soak them in fabric softener and wash them on delicate cycle. When I reload in the spring, the wire ties never interfere with the job.Tom
