loose throttle linkage
Dec 2, 1999
15,184
Harry:
On the earlier boats the pedestal had a set screw under the compass that allow you to add tension to the throttle cable. If you do not have the set screw, then you can get a J-clamp. Check out the archives for additional information.
Dan_Y
Oct 13, 2008
524
Hunter 36 Hampton
The set screw is still there on the 91 H30. I have the same issue.
