Rudder vibration due to a loose rudder post in the sleeve, which appears worn. Yard recommends dropping the rudder and cutting out the tube or sleeve that holds it and fiberglass in a new tube with a tighter tolerance or remove the rudder and wrap the rudder post in self adhesive mylar shim stock to take up the play. Do either of these make sense? Anyone have similar experience with this problem?
