Nodak7: Nice looking boat!! Wish I could see the top of your sails. You'll see why in a minute. If a sailor can sail in light air he can sail in anything.
See my response to Ross in the most recent thread. You've got half of it right - in the higher wind ranges you want to start flatening the sails. In effect you're depowering the sails. At a small boat convention I was speaking at last Feb at Lake Havasu, AZ, a ship mate asked "suppose I don't want to depower my sails in those conditions and want to add more power, what then?". His wife was with him at the time and I asked her if she liked sailing in that manner and she said NO, so I told him "if you like sailing like a maniac and without your wife then have at it and induce as much power as your boat will take - before it breaks!!".
What we're talking about is DRAFT DEPTH (belly). We could use tighter and closer but it's better to use the correct terms so everyones on the same page. In very light winds the wind doesn't have the power to get around the sails and they stall so the sails have to be flat if you want to move the boat forward. As the wind pipes up you want to induce a little belly, which powers up the sail. You have to be careful because if you induce too much belly you'll stall the sails. The higher the wind goes the more draft depth you induce - up to a point and that point is about 25%.
With the boom kicker, which I've never used but I think it works like a boom vang, you're working with another element of sail trim and that's TWIST. When you crank on the boom vang you're closing the top 1/3 of the sail (flatening) and you're powering up the sail so the entire length is driving. When you ease the boom vang you're opening the top 1/3 and spilling air thus depowering the sail since only the bottom 2/3 is driving. Form your hand in a salute and turn your fingers to the right. You've just OPENED up the sail. Turn your fingers to the left and you've CLOSED it. I hate to have to use open and close but that's what it's called. I don't like using draft depth, draft position, angle of attack and twist but I'm stuck with those terms also.
All the sail trim controls for the main and jib work together adjusting 4 elements (draft depth, draft position, twist and angle of attack) and a mate has to know which controls adjust what elements, how they relate to each other or they end up working against each other. I used the analogy yesterday of jambing a sport car shift in second and flooring the accelerator and then pulling up the emergancy brake. If you start to induce draft depth and power up the sails and then twist the sails off and spill power, you're the guy driving the sports car!! I know your not but I couldn't resist.
Does every beginner to intermediate reading this thread understand what is ment by say 25% draft depth or 50% draft position because I'm stuck with those percentages also? If not, sing out and I'll explain it.
